Thanks: gamethai showpicCompatibility : Igo PRIMO 1.1
Resolutions supported : 480x272, 320x240, 800x480 & 480x234
New in this version
Arsiv Downloads for Hiden:
3.1a EUR
- Fixed lang file for 480x272, 480x234 & 800x480
- Fixed display of speed cameras on the map in 480x234 & 320x240
- Possibility to choose the color info maneuvers Chronos
- Adjustments in the navigation screen & language file in 800x480. thank you Tanuki44
- Fits various & varied.
- 320x240: Adaptation data Lucca 2.4L
- Ability to replace the yellow arrows by blue arrows. (Read Installation arrows bleues.txt)
- Change the script tmcchanger:
Note: The script TMCchanger is longer than the other scripts (eg mapchanger). So wait before restarting Primo.
Tmcchanger new script that moves as the TMC Dlls.
The TMC operates change if and only if you do not plug your TMC module while you are in fashion NOTMC
To connect your TMC module, it requires the user to go through before you plug your TMC TMC module.
On some GPS does connect the TMC module, while the mode is NOTMC, works.
Ex: My Mappy 500
On others not, simply plug the module triggers the detection PRIMO.
Ex:
C320/C520 (these two models can be placed on base tmc)
C510
Mappy Mini 290
Medion 460
Each GPS dlls using different versions of Windows different, separate entries in the registry ...
We can not make a tool compatible with all GPS market.
Important: if you empty your save file, do well to return before the primary in TMC.
If you do not do it in first, change your sys.txt to put [tmc] instead of [notmc] and move the dlls folder of TMC primary / primary notmc to the folder.
Installation
- Copy the contents of the directory PRIMO to your root directory Primo. (Accept if asked to overwrite directory / file)
- Retrieve the file "Sounds camera alerts for skin Mioskins Primo" on Miojaco
- Unzip (on your PC) the file "sk_primo_audio_radar_mioskins_wav.zip. you get a folder "Audio".
- Copy the folder "Audio" in the root directory of your Primo.
- Retrieve the file "Sounds alerts drivers for skin Mioskins Primo" on Miojaco
- Unzip (on your PC) the file "sk_Primo_audio_DA_mioskins_wav.zip. you get a folder "Audio".
- First Start
Sys.txt
1 Instructions for the skin
[Sbertaud13]
app = "\ DataFlash \ primo" <= Set the path where the software is installed primo
content = "\ DataFlash \ primo" <= Set the path where the file content is installed
map = "\ DataFlash \ primo" <= Set the path where the file content / map is installed
exename = "igo" (Name of the executable without Primo. "exe". If your executable is called igo.exe then put exename = "igo" / If your executable is called mappy.exe then put exename = "Mappy" )
poi = 1 <= Optional. Put poi = 1 if you also want to switch during the POI mapchanger otherwise do not put the line
tmc_changer = 1; If you have problems with reboot due to the TMC, put this line to activate the change tmc
home = "HOME" <= Optional.
work = "WORK" <= Optional.
as = "CAR" <= Optional.
launch_on_exit = "\ DataFlash \ my directory \ monexe.exe <= Optional. If you want to start a program out of Primo.Mettre the full path to the executable
launch_at_start = "\ DataFlash \ my directory \ monexe.exe <= Optional. If you want to start a program when you start Primo.Mettre the full path to the executable
launch_app = "\ DataFlash \ my directory \ monexe.exe <= Optional. You want to start a program during the execution of primo: add this line and put the right path. Telex / Facsimile a button on the Menu screen.
The app = allows me to know the location of the files save, utility & Catches
The content = lets me know the location of copy.db
The map = lets me know the location map and poi files
The exename = lets me know the name of your executable and for the function serves Panic
2 ° SKin 800x480
Add necessarily
[Interface]
resolution_dir = "800_480"
vga = 0
[Rawdisplay]
Highres = 0
screen_x = 800
screen_y = 480
class = "landscape"
3 ° radar
It is advisable to add
[Warning]
speedcam_max_lookahead = 1000
in sys.txt
4 ° Radar Choup Alerts
- Ability to change its over-speed and tone of the approach using variables sys.txt:
Be careful not to copy the following statement as such in your sys.txt
[Warning]
overspeed_sound = "mon_son1"
approach_beep_sound = "mon_son2"
Mon_son1 mon_son2 and do not exist.
If you want, for example, use sound to another wav sound over-speed:
You have a wav sound file named, for example, dringdring.wav.
Wav file that you copy the audio folder which should be in your file Primo.
Then you add that to your sys.txt
[Warning]
overspeed_sound = "dringdring"
Of course, you do not add
unless you use a personal as his approach to the beep.
- Added ability to customize the 4 custom icons warning in displaying the alert. Add in the sys.txt:
Be careful not to copy the following statement as it is in your sys.txt if the first crash of Primo radar.
[Warning]
user_cam1_bmp = "gfx \ mon_icone1.bmp"
user_cam2_bmp = "gfx \ mon_icone2.bmp"
user_cam3_bmp = "gfx \ mon_icone3.bmp"
user_cam4_bmp = "gfx \ mon_icone4.bmp"
Types of radar T21 T24 types are free. If you do not use it. Go your way, what follows does not interest you.
We let you choose to put a custom image type bmp will be displayed for the radar warning.
The image size must be
53x53 for the resolutions 320x240, 480x234 and 480x272
96x96 to 800x480 resolution
You use the 480x272 resolution, you have a picture of that rest area is named, for example, airederepos.bmp
You crop the image to make it 53x53.
You created a folder in your gfx folder of primary (if it exists already bin there and it's very good)
You copy your image into that folder gfx
you add
[Warning]
user_cam1_bmp = "gfx \ airederepos.bmp"
in your sys.txt
Of course you do not add
If you have not provided image for type T22 to T24.
ลิงค์ครับ
Thanks to Sbertaud13 and kimyaci
