22 มิถุนายน 2024, 17:37:16 *
ผู้เขียน หัวข้อ:  EAT Skin&Mod Primo1.1 "Silver&Gold 6.0" (800x480 & 480x272)  (อ่าน 5198 ครั้ง)
-ได้ให้: 1729
« เมื่อ: 15 มีนาคม 2011, 05:27:59 »
Igo Primo 1.1 Skin & Mod "Silver&Gold 6.0"
Requirements: iGO Primo 1.1 and data resolutions 800x480 or 480x272
Device OS: WinCE / WM
Description: An Exclusive skin for MobilePassion.org for the resolutions 800_480 and 480_272
MAIN FEATURES:
1 - First Igo That Alerts (Audio Visual Or Audio Only) Penalty Points For Speeding. Adapted To The Laws Of Five Countries:France, Germany, Italy, Spain and United Kingdom. More Laws Will Be Incorporated
2 - Three Different Collections Of Icons Of Speed Cameras (by arhd) To Better Adapt To Each Country Or Coordinate Data:
2a.- Original Primo
2b.- Norme EU+
2c.- Used In Several Countries
3 - Different Combinations Of Speed Camera Options.
4 - Adjustment Menu On The Interference Between The Voice Guidance And Voice Alarm.
5 - Delay Setting Voices.
6 - Setting The Warning Distance For Each Speed Camera.
7 - Enable Or Disable For Each Speed Camera.
8 - Choice Of Voices Or Sounds For The Warning
9 - Four Sentences Of Warning:
9a .- Speed Camera Type
9b .- Speed Limit
9c .- Penalty Points
9d .- End Alarm
10 - Possibility To Use 16 Different Languages.
11 - Includes Alarm Voices In The Following Languages:
11a.- English (Female, Male)
11b.- French (Female, Male)
11c.- Italian (Female, Male)
11d.- Spanish (Female, Male)
11e.- German (Male Only)
12 - Compatible With 3D And 2D Cars.
13 - Changing The Size Of The 3D Cars. . One Screen To Show The Effect.
14 - Includes A Collection Of 24 Cars In 2D
15 - New Interfaces Very Easy To Use. Greatly Improves The Handling Of Primo 1.1. “All On One Screen”
16.- Mapchanger (Button In Dragmode)
17 - Possibility To Change Three Different Graphics On The Main Menu.
18 - Changing Font Color. One Screen To Show The Effect
19 - Changing Junction Views. One Screen To Show The Effect.
20 - Over 250 New Graphics.
21 - Possibility Of Removing The Titles Of Buttons Info. Tuning Skin / Navigation
22 - The Speed Cams Alerts Are Wav Sounds, No TTS.
23 - Management Of The Inclination Of The Map In 3D
24 - Function "Avoid U-Turns"
25 - Choice Or Reduce Output Primo Primo Long Press On The Menu
26 - Display Or Not Alternative Routes After Pressing Go
27 - Setting The Display To GO: 0s, 5s and 10s
28 - Various Information on the Top Bar.
29 - Direct button to jump to main menu
30 - Quick Menu By Clicking On The Screen (These Menus Are Deactivated Via The Parameters Of The Skin)
ADDED TO VERSION 6.0
01 .- Possibility to see the next street at the bottom.
02 .- New Quick Menu skin (No. 1). Now with 10 alternatives. This menu is displayed with a touch of "soft" on the screen.
03 .- New Quick Menu skin (No. 2). Customizable. Up to 6 alternatives to choose from 12. Touch "strong" screen.
04 .- Possibility to change the map in a new menu option.
05 .- Collection of 46 cars in 2D. Includes 23 cars free for the user.
06 .- Added notice of penalty points and laws of the following countries / states:
a) Canada (British Columbia)
b) Canada (Quebec)
c) Canada (Ontario)
d) USA (New York)
e) USA (New Hampshire)
f) USA (Vermont)
g) USA (Maine)
h) USA (New Jersey)
i) Poland
j) Brazil
h) Australia (Victoria)
07 .- New voices:
a) German (female)
b) Portuguese / Brazil (female, male). Thanks Escadajr.
08 .- Possibility to show the distance (if less than 200 meters / yards) speedcams in large text.
09 .- New option to scan, edit and delete external programs. (based on Dimka skin)
10 .- Skin credits
11 .- Added the choice of destination with Geo-Photos. 14 destinations are included as examples.
12 .- New option "Cruise Control". Choice of voice or sound message.
13 .- New display for the cockpit configuration options.
14 .- Technical arrangements of the previous version.
Link download
http://uploa...ile/546vph87
MOD SILVER&RED v-6.0 by GJM
SYS.TXT
1A.- ADD MANDATORY (for 800x480 resolution)
resolution_dir="800_480"
vga=0
highres=0
screen_x=800
screen_y=480
class="landscape"
[loading]
show_statustext=0
show_progressbar=1
progressbar_x=72
progressbar_y=437
1B.- ADD MANDATORY (for 480x272 resolution)
resolution_dir="480_272"
vga=1
screen_x=480
screen_y=272
class="landscape"
[loading]
show_statustext=0
show_progressbar=1
progressbar_x=41
progressbar_y=248
2.- FAVORITES.-- Sys txt adjustments of the favorites. You can change the name (always in CAPITAL letters)
[favorites]
1="HOME"
2="WORK"
3.- SCREENSHOTS.-- The files generated during a screenshot are displaced in the folder "captures". Add sys.txt:
[captures]
1 = "\Storage Card\Primo" (If necessary, replace the names "Storage Card" or "Primo" with appropriate names for your installation)
4.- MAPCHANGER.-- Make the following actions:
a.- Add sys.txt:
[mapswitch]
1=",map_ta,\Storage Card\Primo," (If necessary, replace the names "Storage Card" or "Primo" with appropriate names for your installation)
2=",map_nt,\Storage Card\Primo," (If necessary, replace the names "Storage Card" or "Primo" with appropriate names for your installation)
3=",map_ot,\Storage Card\Primo," (If necessary, replace the names "Storage Card" or "Primo" with appropriate names for your installation)
b.-In "utility\MapChanger.nfrun" (at end of file)
RUN "$iGOPrg$iGO.exe" (If necessary, replace the name "iGO.exe" with appropriate name for your installation)
c.-In "utility\MapChanger.ini"
[mapchanger]
swpoi=1 (0 for 0 for no change pois)
DirContent=\Storage Card\Primo\content (If necessary, replace the names "Storage Card" or "Primo" with appropriate names for your installation)
DirSave=\Storage Card\Primo\save (If necessary, replace the names "Storage Card" or "Primo" with appropriate names for your installation)
ExePathName=\Storage Card\Primo\iGO.exe (If necessary, replace the names "Storage Card" or "Primo"or "iGO.exe with appropriate names for your installation)
If a) this does not work properly, replace these lines in the sys.txt
[switchmap]
changer="\Storage Card\Primo\utility\MapChanger.exe" (If necessary, replace the names "Storage Card" or "Primo" with appropriate names for your installation)
5.- ICON CHANGE (speed camera).-- Add sys.txt: (type ";" at the start line to clear)
[map]
speedwarn_icon="$speedwarn.spr" ;default (collection #1) or
speedwarn_icon="$speedwarn_2.spr" ;(for collection #2) or
speedwarn_icon="$speedwarn_3.spr" ;(for collection #3)
6.- GEO-PHOTOS (If necessary, replace the name "Storage Card" with appropriate name for your installation)
[oasis]
exclude_directories="%root%/Application Data,%root%/Program Files,%root%/Windows,PICTURE::%app%",MUSIC::%SDCARD%/,MUSIC::%myflashdisk%/"
include_directories="GAME::%app%/content/games,PICTURE::%SDCARD%/GEO-PHOTOS/,MUSIC::%myflashdisk%/music,MUSIC::%SDCARD%/musi
Link download
http://uploa...ile/nb424ah6
Thanks to elestor and Kimyaci
ที่มา   www.igo8navigation.com
ROM YF 84 A CHINESE ครับ"RomVersion : 84A.YF.5.A.0613 silver"
ห้องรอม
eak_1v 2 7857 กระทู้ล่าสุด 28 กันยายน 2009, 22:01:23
โดย eak_1v
Gold menu for iGO Primo 480x272 RC1
^SuRaYoOt^ 0 3855 กระทู้ล่าสุด 15 มิถุนายน 2010, 05:50:09
picto skin for primo1.1 สำหรับ 800x480 เท่านั้น [ปรับสีได้ตามใจชอบ]
keang-kt 0 3468 กระทู้ล่าสุด 19 สิงหาคม 2010, 15:23:25
โดย keang-kt
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.033 วินาที กับ 38 คำสั่ง
