21 มิถุนายน 2024, 12:52:14 *
ผู้เขียน หัวข้อ:  Skin diMka WA P.1.3.7 for Primo 1.2 (9.2.0.x, 9.2.1.x) 03-09-2011  (อ่าน 3276 ครั้ง)
₪๐StemCell๐₪
ผู้ดูแลกติกา
คนพิเศษ
ID number: 3
$4000.11 credits
Send Money to ₪๐StemCell๐₪
-ได้ให้: 829
-ได้รับ: 10413
« เมื่อ: 04 กันยายน 2011, 09:00:31 »
Skin diMka WA (WertVRV and Andron66) for 320x240, 480h234, 480x272, 800x480 (for Primo 1.2) (9.2.0.x, 9.2.1.x).
The current version of P 1.3.7
Do not forget to say thank you to:
Andron66 - all pictures by the skin (for 800_480 completely redrawn almost all the pictures in high quality).
dima8389 - author of the original skin di / \ / \ ka for iGO8.3, many of whom moved to the skin for Primo.
psb - author decompiler file *. lua, without which there would be no skins.
What new , What Change , What Fix
1. Added setting priorities TTSPro-voice-camera warning, signs of DA and the voice instructions (TTSPro-menu):
1) option - Warnings Support: TTSPro-voice camera warning signs and DA has priority over the voice-over, ie a phrase about the cameras and signs of dropping off voice guidance on routes and not the voice instructions until the end of the phrase chambers or signs;
2) option - Escort Warnings: voice guidance takes precedence over the voice acting TTSPro-camera warning signs and DA, Ie the phrase about the cameras and signs are interrupted by voice-over on the route and there will be voice-camera warning signs and DA, while not finish the sentence Voice warnings on the route.
Other TTSPro-voice-have a lower priority than the camera warning, Marks DA, and voice guidance.
2. Added the ability to prevent an increase in road speed limits:
- Switching off a visual warning (animated character limit) in the cockpit and screen saver;
- Audible warning with a choice of sound and volume settings;
- TTSPro-voice warning about the increase in road speed limits (the phrase "You can increase the speed. Restricting x miles per hour.") (Listen to and enable / disable the additional sentence may be the speed limit once the menu (the button to go to the screen test voice-activated when included mainly and the sound of the voice instructions) when you turn a standard voice-related settings are inactive).
Enable / disable in the menu will be available TTSPro with the support of TTS-voice such a possibility, ie the presence of \ i18n \ dictionary.voice voice file such a block transfer (for example, Russian TTS):
Code
You can increase speed .= "You can increase the speed."
Limit% s = "limit% s"
Preventing an increase in road speed limit is only in the case of exceeding a speed, ie if the current speed is less than the new value of the only restriction.
Reduced speed limits and road warning in case of excess irrelevant, because at the moment running a warning (visual and audible) on the excess.
สนใจติดตามได้ที่ web นอกนะครับ  http://4pda.ru/forum/index.php?showtopic=172002&st=3380#entry6999565
MIRROR
igo primo ลง skin dimka 1.5.3 แล้ว Failed to open file: ui_igo9\common\junctionv
daplab 1 3915 กระทู้ล่าสุด 26 กุมภาพันธ์ 2014, 10:45:45
โดย Dynax505
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.026 วินาที กับ 38 คำสั่ง
