25 มิถุนายน 2024, 12:59:44 *
หน้า: [1] 2   ลงล่าง
ผู้เขียน หัวข้อ:  น้ำแข็งใส หลากรส (Silver&Gold Skin version 7.5 for primo2.0)  (อ่าน 31330 ครั้ง)
✄PiGGer✄
ชีวิต..ฉัน..เป็น..ของฉัน
s8lt memberDonate
ID number: 3608
กระทู้: 1047
Send Money to ✄PiGGer✄
-ได้ให้: 856
-ได้รับ: 3125
« เมื่อ: 22 กุมภาพันธ์ 2012, 12:27:28 »
 Ok
Silver&Gold version 7.5 (480x272)
Requirements: Igo Primo 2.0
Operating System: WinCE/WM
คุณลักษณะของน้ำแข็งใสถ้วยนี้
01 - Compatible only with Primo 2.0
02 - Resolutions supported: 800_480, 472x280, 400x240 and 320x240
03 - We recommend using the following path: "xxx / primo / mobilenavigator.exe". Where "xxx" is the name that you assign your PDA / PNA to the place where you install the browser
04 - It has been built and improvements made by Dimka and Sbertaud13
05 - Skin resident in the branding.
06 - First Igo Primo alerting (Audio Visual or audio only) of penalty points for speeding.
It is adapted to the following laws:
a) Canada (British Columbia)
b) Canada (Quebec)
c) Canada (Ontario)
d) USA (New York)
e) USA (New Hampshire)
f) USA (Vermont)
g) USA (Maine)
h) USA (New Jersey)
i) Poland
j) Brazil
h) Australia (Victoria)
i) Spain
j) England
k) France
l) Germany
m) Italy
07 - Three different collections of icons radar to better suit each country or coordinate data you have.
a. - Original Primo
b. - Standard EU +
c. - Used in several countries..
08 - Different combinations of options under the radar.
09 - Set the menu on the interference between the voice guidance and voice alarm.
10 - Adjusting the delay of the voices.
11 - Set the warning distance for each radar.
12 - Enable or disable each type of radar.
13 - Selection of voices or sounds warning
14 - Four words of warning (heard sequentially):
a .- Speed Camera Type
b .- Speed Limit
c .- Penalty Points
d .- End Alarm
15 - Ability to use 16 different languages.
16 - Includes the voices of alarm in the following languages:
a.- English (Female, Male)
b.- French (Female, Male)
C.- Italian (Female, Male)
d.- Spanish (Male, Female)
e.- German (Female, Male)
f.- Portuguese / Brazil (Female, Male). Thanks Escadajr
17 - Compatible with 3D and 2D car.
18 - Change the size of the 3D car. A screen to show the effect.
You can choose between:
a. - Size 60%
b. - Size 80%
c. - Size 100%
d. - Size 120%
e. - Size 140%
19 - Level of transparency of the buttons and information
20 - very easy to use interfaces. Significantly improves handling Primo 1.2. "Everything on the screen"
21 - Changing color of fonts. A screen to show the effect
22 - Changing the color of the arrows
23 - Change "lane assistant". Three different possibilities. Screen to show the effect.
24 - More than 320 new graphics.
25 - Ability to delete button for information. Optimization of skin / navigation
26 - Mapchanger for three providers without having to manipulate the sys.txt.
27 - camera alerts are WAV sounds, no TTS.
28 - Management of tilting the map in 3D
29 - Role of "avoiding turning 180 degrees"
30 - Various functions with the long press of the button or speed.
31 - Show or no alternative routes after pressing "go."
32 - Setting the display to "go": 0s, 5s and 10s
33 - various information on the top bar
34 - Number of output for roundabouts in the second maneuver.
35 - Quick Menu (No. 1) of the skin. It is activated by clicking a "soft" on the screen.
Ten quick links without the possibility of customization.
Menu can be disabled.
36 .- Menu (No. 2) Quick skin. It is activated by clicking "strong" on the screen.
Customizable. Up to 6 alternatives to choose from 12.
Indication of each alternative on the screen
37 .- Possibility to switch the number of the street on the right / left of the screen.
38 .- Possibility to see the next informaciónde the street at the bottom of the screen
39 .- Possibility to change the map from menu or DragMode.
40 .- Choice of xenon mostar compass between two sizes.
41 .- Possibility to display the distance to the radar in large text (if the distance is less than 200 meters / yards).
42 .- Option to scan, edit, run and delete external programs.
43 .- Skin credits
44 .- Added the choice of destination with Geo-Images. 14 destinations are included as examples.
45 .- Option "Cruise Control". Choice of the warning voice or sounds.
46 .- Special screen divided into drawers for cabin configuration options.
47 .- Mapchanger the following possibilities for change:
a. - Only Map
b. - Map + Poi
c. - Map + Poi + Buildings
d. - Map + Poi + Buildings + Dem
e. - Map + Poi + Buildings + Dem + Phoneme
f. - Map + Poi + Buildings + Dem + Phoneme + Histspeed
48 .- Brandingchanger. This option installs the original manufacturer branding, allowing compatibility with other skin living in the path / content / skin.
49 .- Main Menu Customizer similar to that in the current smartphones. This option allows:
Choose between buttons representing words or icons.
Choice of 25 different choices of attachment.
Choice of 0 to 15 quick links and paste them into place you want to display.
28 screens in the background.
Allows thousands of different combinations.
50 .- CarChanger 2D collections made by GJM. They are installed in the "content/skin". Contains:
a. - Audi
b. - Mercedes Benz
c. - Porsche
d. - Lexus
e. - Mini Cooper (pack 1)
f. - Mini Cooper (pack 2)
g. - Concept Car
h. - Miscellaneous (elastor)
i).- BMW
51 .- Backgroundschanger. Choose between 13 different models.
52 .- Icons_speed_camera_Changer (section 07) of speed cameras by using menu. It eliminates the need to program the sys.txt
53 .- Special calibration (two types) to solve the incompatibility problems that have some PDA/PNA with PRIMO 2.0
54.- Road lights for cars 2D
55.- Flashers to address some of the cars 2D
57.- Note trip (post-it) to remember to perform some action (phone call, buy food, etc). Programmable to alert at a specific time.
58.- Improved design options for a better understanding. It avoids the vertical scroll
59.- Changer pictures to close the program (Existing)
60.- Telepules changer. Attached 7 collections.
61.- 2D Changer cars.
62.- No need to modify the sys.txt for the proper functioning of all changers
63.- Voices improved (Spanish only)
64.- New "diricons" (BY GJM)
65.- SCHEME BY ELCHOTOVOLADOR
66. - Changes of icons and color for maneuvers.
67. - Improved management of pois.
68. - Change of site penalties icons.
69. - 6 car collections 2D customizable by the user (use GJM collection)
70.- Arrive Settings
รสชาติน้ำแข็งใสที่มีรูปแบบหน้าตาแตกต่างกัน ให้เลือกชิมกันมากมาย
เครื่องเคียง ทำให้รสชาติกลมกล่อมมากขึ้น
ที่สำคัญน้ำแข็งใสถ้วยนี้จัดวาง Junction View ได้ตามใจชอบ กลาง หรือ ข้างก็ได้หมด
เสียงเตือน ในการชิมน้ำแข็งใส
และสามารถเตือนความจำผ่านจานน้ำแข็งใสได้อีกด้วย ถือว่าเป็นความแปลกใหม่
ภาพขนม (รถ) มากมายให้เลือก รวมทั้งภาพของน้ำแข็งใสสำเร็จรูปด้วย
น้ำแข็งใส หลากรส
Thank : KEMAl by Navi-gpsforum
« แก้ไขครั้งสุดท้าย: 27 พฤษภาคม 2012, 19:50:50 โดย ✄PiGGer✄ » บันทึกการเข้า
naija
ID number: 33453
กระทู้: 32
Send Money to naija
-ได้ให้: 26
-ได้รับ: 36
« ตอบ #1 เมื่อ: 22 กุมภาพันธ์ 2012, 13:00:37 »
ไฟล์ใน 480x272 เป็น 800x480 ซ้ำ
« แก้ไขครั้งสุดท้าย: 22 กุมภาพันธ์ 2012, 13:25:09 โดย naija » บันทึกการเข้า
ถ้ารู้คงไม่ถาม ที่ถามเพราะไม่รู้
naija
ID number: 33453
กระทู้: 32
Send Money to naija
-ได้ให้: 26
-ได้รับ: 36
« ตอบ #2 เมื่อ: 22 กุมภาพันธ์ 2012, 13:49:41 »
แก้ไขจาน 480x272 ให้เรียบร้อยแล้วครับ ถ้าอยากได้แบบ Mod อาจจะมี Surprise เร็ว ๆ นี้
ปล. เสียงเตือน ตัวนี้อยู่ระหว่างจัดทำ ตอนนี้ผมใช้ Sys ทำงานไปก่อน สำหรับรูปภาพเตือน ยังไม่ได้ Mod เข้าไป  ค้นหา
สุดยอดครับ  กำเสี่ย กำเสี่ย กำเสี่ย
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #3 เมื่อ: 22 กุมภาพันธ์ 2012, 14:10:39 »
มีหลายคนสอบถามถึงวิธีลงผ่าน PM มา ผมขออนุญาติ โพสไว้ในกระทู้แล้วกันนะครับ  ค้นหา
วิธีการลง 1.  แตกไฟล์ Silver&Gold_7_5_ตามขนาด.rar แล้วจะได้ Folder ชื่อ
               - Skin
               - VERY_IMPORTAND
           2.  เข้าไปที่ Folder skin แล้วแตกไฟล์ Branding.zip และ Branding_nng.zip ออกมา เพื่อนำ branding ของเดิมใส่เพิ่มเข้าไป แล้วทำการ Zip กลับเข้าไปใหม่ทั้ง 2 branding (ระวังไฟล์สปีดแคม ถ้าอยากได้ของเดิม ก็อย่าลงทับ จะอยู่ใน ui_igo9/ตามขนาด)
           3.  ทยอยใส่ Folder แต่ละตัวลงไปค่อย ๆ ใส่ ที่สำคัญ Folder content/car จะต้องแยกเป็น car 3D และ car 2 D เพื่อนำมาใช้ที่แตกต่างกัน
           4.  สำหรับ folder audio/gfx/ui_igo9/utility ต้องใส่ไว้ใน folder Primo นะครับ
           5.  Backup file เดิมทั้งหมดเก็บไว้ อย่าลืม ที่เหลือใช้ความสามารถพิเศษ หรือรอ Surprise แบบเงียบ ๆ ต่อไป
naija
ID number: 33453
กระทู้: 32
Send Money to naija
-ได้ให้: 26
-ได้รับ: 36
« ตอบ #4 เมื่อ: 22 กุมภาพันธ์ 2012, 15:13:29 »
ผมเชื่อว่าอีกหลายๆท่าน(สำหรับมือใหม่)น่าจะยัง งงๆกับข้อ  2.  เข้าไปที่ Folder skin แล้วแตกไฟล์ Branding.zip และ Branding_nng.zip ออกมา เพื่อนำ branding ของเดิมใส่เพิ่มเข้าไป (ของเดิม ในที่นี้หมายถึง.......)  กำเสี่ย กำเสี่ย กำเสี่ย
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #5 เมื่อ: 22 กุมภาพันธ์ 2012, 15:45:41 »
ตัวนี้จะมีคุณสมบัติหลายอย่าง เช่น Poi Icon หรือ การตกแต่งสกิน หรือ ตัวโปรแกรม เพราะฉะนั้น ของเดิม ในที่นี่ จะหมายถึง ถ้าคุณอยากได้อะไรที่กล่าวมาแล้วอยู่
ก็เก็บมารวมกันครับ  สรุปง่าย ๆ คือ ต้องศึกษา common scheme และ icons ให้เข้าใจก่อนครับ
naija
ID number: 33453
กระทู้: 32
Send Money to naija
-ได้ให้: 26
-ได้รับ: 36
« ตอบ #6 เมื่อ: 22 กุมภาพันธ์ 2012, 15:48:56 »
เข้าใจแล้วครับ...... กำเสี่ย กำเสี่ย กำเสี่ย
naija
ID number: 33453
กระทู้: 32
Send Money to naija
-ได้ให้: 26
-ได้รับ: 36
« ตอบ #7 เมื่อ: 22 กุมภาพันธ์ 2012, 19:10:11 »
อลังการงานสร้าง จริงๆคับ
เห็นเมนูและไอคอน มึนเลยคับ.....อิอิ จิ้มอะไรไม่ถูกเลย  อยากตาย อยากตาย อยากตาย
สุดยอดคับ มีเปิดไฟหน้ากลางคืนด้วย
« แก้ไขครั้งสุดท้าย: 22 กุมภาพันธ์ 2012, 19:14:35 โดย naija » บันทึกการเข้า
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #8 เมื่อ: 23 กุมภาพันธ์ 2012, 07:44:37 »
มีให้เลือกหน้าจอสกิน 2 แบบนะครับ แบบที่ผมโชว์เป็นแบบที่ 1  สำหรับแบบที่ 2 เป็นแบบที่เราคุ้น ๆ กัน คือมีภาพนำทาง และคำสั่ง ค้นหา เส้นทาง และเพิ่มเติม ครับ
สำหรับหน้าจอสกินที่ 2 น่าจะคุ้นกว่านะครับ ลองทดสอบดูครับ
naija
ID number: 33453
กระทู้: 32
Send Money to naija
-ได้ให้: 26
-ได้รับ: 36
« ตอบ #9 เมื่อ: 23 กุมภาพันธ์ 2012, 08:34:32 »
งานเข้าครับคุณ ✄PiGGer✄ ไอคอน poi ผมเป็นวงกลมสีฟ้าและสีเหลืองหมดเลยครับ ผมลงอะไรผิดหรือเปล่า
pali
ID number: 31814
กระทู้: 98
Send Money to pali
-ได้ให้: 132
-ได้รับ: 111
« ตอบ #10 เมื่อ: 23 กุมภาพันธ์ 2012, 13:03:32 »
ลองลงใหม่ครับ ตอนลงครั้งแรกของผม icon ผมก็ไม่ขึ้น ลบแล้วลงใหม่ก็มาเป็นปกติดี
วันนี้ลองเพิ่ม skin dimka_tomsoft_153a ไปเพราะถ้าไม่ลงจะใช้ tts pro ไม่สมบูรณ์ ไม่รู้ท่านอื่นเป็นหรือเปล่า
« แก้ไขครั้งสุดท้าย: 23 กุมภาพันธ์ 2012, 13:06:49 โดย pali » บันทึกการเข้า
naija
ID number: 33453
กระทู้: 32
Send Money to naija
-ได้ให้: 26
-ได้รับ: 36
« ตอบ #11 เมื่อ: 23 กุมภาพันธ์ 2012, 17:11:30 »
ลงได้แล้วครับ icon  มาเป็นปกติแล้ว ใช้ tts pro ไม่ครบเหมือนกัน แต่ถ้าลงสกินเพิ่ม ก็จะใช้ น้ำแข็งใส หลากรส ได้ไม่สมบูรณ์เช่นกัน แต่ถ้าได้ท่านสมาชิกมาปรุงแต่งใหม่ผมว่าน่าใช้มากทีเดียวเลย
-ได้ให้: 1500
« ตอบ #12 เมื่อ: 23 กุมภาพันธ์ 2012, 23:18:22 »
เกี่ยวกับเรื่องเสียงได้ลองชุด  tts_nua_v5  ขนาด 86 M  หรือยังครับ
ดูในกระทู้นี้โหลดมาก่อนทัั้งหมดแล้วเลือกเอาแต่เฉพาะ  tts_nua_v5  ขนาด  86  M มาใช้
http://www.n...topic=2992.0
kkmnsc
Exp 10-07-2011
ID number: 117
กระทู้: 113
$65.01 credits
Send Money to kkmnsc
-ได้ให้: 156
-ได้รับ: 230
« ตอบ #13 เมื่อ: 24 กุมภาพันธ์ 2012, 08:31:15 »
ของผมก็เจอปัญหาคือ ICON มันขึ้นแล้วแหละแต่พอผมเปลี่ยน skin ใหม่ แล้ว restart ปรากฎว่า hang เลยครับ  ต้องเข้าไปลบ ข้อมูลใน folder save ทิ้งไปแล้วเริ่มใหม่ถึงจะ ok แล้ว set ระบบใหม่  ลองเปลี่ยน skin ก็ไม่ hang ครับ  ลองดูนะครับเผื่อจะเป็นแบบผมครับ
kitichat
ID number: 93
กระทู้: 50
$460.10 credits
Send Money to kitichat
-ได้ให้: 376
« ตอบ #14 เมื่อ: 24 กุมภาพันธ์ 2012, 12:13:42 »
ผมเคยโหลดตัวนี้จากเวปนอกมาใช้ชอบมากเลย เสียดายไม่มี poi icon สวยๆเหมือนในเวปเรา เคยเอา
poi icon ในเวปเราไปใส่ตามที่คุณ pigger บอกตามข้อ2 แต่ทำไม่ได้สักที ไม่ทราบว่าต้องเอา
folder/file ไหน ไปใส่ตรงไหนบ้างและแก้อะไรอีกบ้าง ขอความอนุเคราะห์จากผู้ใจดี ช่วยบอกขั้นตอน
ให้ละเอียดได้ไหมครับ ผมไม่มีความรู้จริงๆ พยายามอ่านโดยละเอียดและหาข้อมูลแล้วก็ทำไม่ได้
เปิดดูที่เขาปรุง poi icon ไม่ใส่ไว้ที่ folder ตาม res หน้าจอ เช่น 800x480 หรือ 480x272
ก็ใส่ไว้ใน folder common ผมลอง copy ไปใส่ก็ไม่ได้ ไม่ทราบว่าถูกหรือเปล่า ขอบคุณมากครับ
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #15 เมื่อ: 24 กุมภาพันธ์ 2012, 21:54:44 »
ใส่เข้าไปทั้งหมดเลยก็ได้ครับ สำหรับไฟล์ตัวใหม่ที่ใส่เข้าไปใน ui_igo9/ขนาดสกิน/"""
จะได้ไฟล์ใหม่เปลี่ยนไป เช่น
 bdiricon_000.bmp ของเดิม icon_000.bmp หรือ
เป็นต้นครับ
สำหรับ common และ icon ใส่ทับตัวใหม่ไปเลยครับ ลองทดสอบดูครับ
-ได้ให้: 1500
« ตอบ #16 เมื่อ: 06 มีนาคม 2012, 00:35:33 »
ผมไม่ต้องการเสียงเตือนจากในระบบ  skin ที่เป็นเสียงต่างชาติ  เตือน speed limit  จำกัดความเร็ว  กับเตือน speedcam   เพราะชอบเสียงเตือนจากนาริสามากกว่า  พอไปปิดไม่ให้เสียงฝรั่งร้องเตือนกลายเป็นปิดเสียงนาริสาไปด้วย  พอลองเปลี่ยนเสียงเตือนฝรั่งเป็นเสียงดนตรีแทน  ก็มักจะดังขัดจังหวะขณะที่นา่ริสากำลังจะพูดพอดี  ทำให้พูดไม่จบประโยค   เคยลองเอาชุดเสียง  audio  ออกจากโปรแกรมไปเลย   ปรากฎว่าค้างขณะนำทาง  เข้าใจว่าระบบจะส่งเสียงเตือนแต่ไม่พบไฟล์เสียง
ไล่ไปไล่มาเลยลองแก้ใน  ไฟล์  igo9.ini   ซึ่งอยู่ใน  branding \ project_config \
พอเปิด  igo9.ini  แล้วลองลบ
[sound.announcer]
overspeedlimit_source=ui
และ
[subscriptions.community_speedcam]
timelimit_warnings=7,1
เพื่อไม่ใช้เสียงเตือนจากชุด skin  ทำงาน   แต่เสียงอย่างอื่นยังมีอยู่ เช่น เสียงแนเะนำเข้า ออก โปรแกรม
คำถาม คือ หากผมลบสองท่อนข้างต้นนั้นออกจะถูกหรือไม่ครับ
ซึ่งได้ลองระยะทางสั้นๆรู้สึกว่าช่วยได้บ้าง   ยังไม่มีเสียงฝรั่งส่งเสียงเตือน  โดยนาริสายังทำงานปกติอยู่
« แก้ไขครั้งสุดท้าย: 06 มีนาคม 2012, 00:37:11 โดย fortune » บันทึกการเข้า
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #17 เมื่อ: 06 มีนาคม 2012, 22:21:55 »
[sound.announcer]
และ
ตอนนี้น้ำแข็งใสของผมใช้เป็นเสียงที่มาในชุด เช่น เสียงหัวเราะ หรือ เสียงกรี๊ด เพราะกำลังทำเสียง TTS อยู่ แต่ยังไม่เสร็จ
ซึ่งจากที่สอบถามมายังไม่ได้ลอง และไม่มีเสียงซ้อนนะครับ เดี๋ยวจะลองดูครับว่า
[sound.announcer]
และ
2 ส่วนนี้สามารถแก้ไขได้หรือเปล่า
-ได้ให้: 1500
« ตอบ #18 เมื่อ: 07 มีนาคม 2012, 00:13:28 »
มาอัพเดทข้อมูลครับ  เมื่อเย็นลองใช้วิ่งช่วงผ่านทางด่วนบางนา มา ดินแดงจะมีจุดเตือนกล้องหลายแห่ง   ก็เสียงในระบบยังทำงานอยู่ครับ
แต่เสียงเตือนจำกัดความเร็วช่วงสะพาน  ทางโค้ง  ชุมชน ฯลฯ  ไม่ทำงานแล้ว
ทำให้  เสียงเตือนพวก speedcam ทั้งหลายจะดังทั้งนาริสาและในระบบ  ผมเลยใช้วิธีเลี่ยงไม่ให้ดังพร้อมกันโดยไปตั้งค่าเลือกความเร็วต่อระยะส่งเสียงเตือนให้เหลื่อมกับนาิริสาเล็กน้อย  เช่น  นาริสา ผมไปตั้งใน  sys.txt  จะตั้งให้เริ่มเตือนที่ 1000  1500  2000 แล้วแต่ความชอบ และเตือนซ้ำ 500    ส่วนเสียงในระบบผมตั้งให้เตือนที่ 750  ทุกความเร็วไม่ว่าวิ่งด้วยความเร็วเท่่าไรจะให้เตือนที่ 750  ครับ
-ได้ให้: 1500
« ตอบ #19 เมื่อ: 07 มีนาคม 2012, 13:25:27 »
ผมพึ่งทราบอีกอย่างว่า  เมื่อผมได้เลือกใส่ไฟล์   user  ที่แสดงพิกัดต่างๆ  พิกัดที่เลือกเอาไว้เป็นพวก  Bank  Bigicon  BTS  LPG  NGV  ฯลฯ  ใส่ไว้ใน  default  พร้อมทั้ง  poi_visibilities  ทำให้แสดง  icon poi บนแผนที่แล้ว
ตอนเข้าเมนูค้นหาก็ยังแสดงเป็นหมวด หมู่  สะดวกแก่การค้นหาด้วย
ค้นสถานที่ > ค้นหาแบบกำหนดเอง > บริเวณตำแหน่งสุดท้ายที่ทราบ > หน้าต่อไปเข้าหมวดรายการต่างๆ
ลักษณะภาพ
แต่พอผมก็อปไฟล์  user  ต่างหากอีกไฟล์ซึ่งเป็นไฟล์บันทึกรายการโปรดจากเวอร์ชั่นเก่ามาใช้  เอาไปใส่ใน  save \ profiles \ 01 \ user   เพื่อนำมาใช้ต่อ    ปรากฎว่า  หมวด  หมู่  พวก  Bank  Big icon ฯลฯ  หายไป   คงเหลือแต่หมวด หมู่  ที่เซ็ตเอาไว้จากโปรแกรม
ผมลองไล่ไปไล่มา  ถึงทราบว่า  ต้องเปิด user ไฟล์บันทึกรายการโปรด  และก็อปเอารายชื่อ  พิกัดข้างในออกมา   มาวางต่อท้ายเข้าไปใน  ไฟล์  user  ของพวก  Bank  Big icon    ฯลฯ ที่อยู่ใน  default  ถึงทำให้  หมวด  หมู่  ต่างๆของพวก  Bank  Big icon    กลับมาให้ใช้ที่การค้นหาเหมือนเดิม
แต่ก่อนก็อปชื่อ  พิกัด จากรายการโปรดมาวางรวม   ผมได้เปลี่ยนตัวเลขลำดับที่หน้าแต่ละพิกัดรายการโปรด  ให้เป็นตัวเลขนับต่อจากพวก  Bank  Big icon
หน้า: [1] 2   ขึ้นบน
GJmpp_v1.12D silver A66 F63 and Gold
^SuRaYoOt^ 2 4939 กระทู้ล่าสุด 27 กรกฎาคม 2010, 10:40:51
โดย Papabear
Skin Mod Silver BRUNODU91
^SuRaYoOt^ 0 3156 กระทู้ล่าสุด 30 กันยายน 2010, 01:54:16
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.106 วินาที กับ 66 คำสั่ง
