25 มิถุนายน 2024, 13:51:33 *
ผู้เขียน หัวข้อ:  น้ำแข็งใส หลากรส (Silver&Gold Skin version 7.5 for primo2.0)  (อ่าน 31344 ครั้ง)
✄PiGGer✄
ชีวิต..ฉัน..เป็น..ของฉัน
s8lt memberDonate
ID number: 3608
กระทู้: 1047
Send Money to ✄PiGGer✄
-ได้ให้: 856
-ได้รับ: 3125
« เมื่อ: 22 กุมภาพันธ์ 2012, 12:27:28 »
 Ok
Silver&Gold version 7.5 (480x272)
Requirements: Igo Primo 2.0
Operating System: WinCE/WM
คุณลักษณะของน้ำแข็งใสถ้วยนี้
01 - Compatible only with Primo 2.0
02 - Resolutions supported: 800_480, 472x280, 400x240 and 320x240
03 - We recommend using the following path: "xxx / primo / mobilenavigator.exe". Where "xxx" is the name that you assign your PDA / PNA to the place where you install the browser
04 - It has been built and improvements made by Dimka and Sbertaud13
05 - Skin resident in the branding.
06 - First Igo Primo alerting (Audio Visual or audio only) of penalty points for speeding.
It is adapted to the following laws:
a) Canada (British Columbia)
b) Canada (Quebec)
c) Canada (Ontario)
d) USA (New York)
e) USA (New Hampshire)
f) USA (Vermont)
g) USA (Maine)
h) USA (New Jersey)
i) Poland
j) Brazil
h) Australia (Victoria)
i) Spain
j) England
k) France
l) Germany
m) Italy
07 - Three different collections of icons radar to better suit each country or coordinate data you have.
a. - Original Primo
b. - Standard EU +
c. - Used in several countries..
08 - Different combinations of options under the radar.
09 - Set the menu on the interference between the voice guidance and voice alarm.
10 - Adjusting the delay of the voices.
11 - Set the warning distance for each radar.
12 - Enable or disable each type of radar.
13 - Selection of voices or sounds warning
14 - Four words of warning (heard sequentially):
a .- Speed Camera Type
b .- Speed Limit
c .- Penalty Points
d .- End Alarm
15 - Ability to use 16 different languages.
16 - Includes the voices of alarm in the following languages:
a.- English (Female, Male)
b.- French (Female, Male)
C.- Italian (Female, Male)
d.- Spanish (Male, Female)
e.- German (Female, Male)
f.- Portuguese / Brazil (Female, Male). Thanks Escadajr
17 - Compatible with 3D and 2D car.
18 - Change the size of the 3D car. A screen to show the effect.
You can choose between:
a. - Size 60%
b. - Size 80%
c. - Size 100%
d. - Size 120%
e. - Size 140%
19 - Level of transparency of the buttons and information
20 - very easy to use interfaces. Significantly improves handling Primo 1.2. "Everything on the screen"
21 - Changing color of fonts. A screen to show the effect
22 - Changing the color of the arrows
23 - Change "lane assistant". Three different possibilities. Screen to show the effect.
24 - More than 320 new graphics.
25 - Ability to delete button for information. Optimization of skin / navigation
26 - Mapchanger for three providers without having to manipulate the sys.txt.
27 - camera alerts are WAV sounds, no TTS.
28 - Management of tilting the map in 3D
29 - Role of "avoiding turning 180 degrees"
30 - Various functions with the long press of the button or speed.
31 - Show or no alternative routes after pressing "go."
32 - Setting the display to "go": 0s, 5s and 10s
33 - various information on the top bar
34 - Number of output for roundabouts in the second maneuver.
35 - Quick Menu (No. 1) of the skin. It is activated by clicking a "soft" on the screen.
Ten quick links without the possibility of customization.
Menu can be disabled.
36 .- Menu (No. 2) Quick skin. It is activated by clicking "strong" on the screen.
Customizable. Up to 6 alternatives to choose from 12.
Indication of each alternative on the screen
37 .- Possibility to switch the number of the street on the right / left of the screen.
38 .- Possibility to see the next informaciónde the street at the bottom of the screen
39 .- Possibility to change the map from menu or DragMode.
40 .- Choice of xenon mostar compass between two sizes.
41 .- Possibility to display the distance to the radar in large text (if the distance is less than 200 meters / yards).
42 .- Option to scan, edit, run and delete external programs.
43 .- Skin credits
44 .- Added the choice of destination with Geo-Images. 14 destinations are included as examples.
45 .- Option "Cruise Control". Choice of the warning voice or sounds.
46 .- Special screen divided into drawers for cabin configuration options.
47 .- Mapchanger the following possibilities for change:
a. - Only Map
b. - Map + Poi
c. - Map + Poi + Buildings
d. - Map + Poi + Buildings + Dem
e. - Map + Poi + Buildings + Dem + Phoneme
f. - Map + Poi + Buildings + Dem + Phoneme + Histspeed
48 .- Brandingchanger. This option installs the original manufacturer branding, allowing compatibility with other skin living in the path / content / skin.
49 .- Main Menu Customizer similar to that in the current smartphones. This option allows:
Choose between buttons representing words or icons.
Choice of 25 different choices of attachment.
Choice of 0 to 15 quick links and paste them into place you want to display.
28 screens in the background.
Allows thousands of different combinations.
50 .- CarChanger 2D collections made by GJM. They are installed in the "content/skin". Contains:
a. - Audi
b. - Mercedes Benz
c. - Porsche
d. - Lexus
e. - Mini Cooper (pack 1)
f. - Mini Cooper (pack 2)
g. - Concept Car
h. - Miscellaneous (elastor)
i).- BMW
51 .- Backgroundschanger. Choose between 13 different models.
52 .- Icons_speed_camera_Changer (section 07) of speed cameras by using menu. It eliminates the need to program the sys.txt
53 .- Special calibration (two types) to solve the incompatibility problems that have some PDA/PNA with PRIMO 2.0
54.- Road lights for cars 2D
55.- Flashers to address some of the cars 2D
57.- Note trip (post-it) to remember to perform some action (phone call, buy food, etc). Programmable to alert at a specific time.
58.- Improved design options for a better understanding. It avoids the vertical scroll
59.- Changer pictures to close the program (Existing)
60.- Telepules changer. Attached 7 collections.
61.- 2D Changer cars.
62.- No need to modify the sys.txt for the proper functioning of all changers
63.- Voices improved (Spanish only)
64.- New "diricons" (BY GJM)
65.- SCHEME BY ELCHOTOVOLADOR
66. - Changes of icons and color for maneuvers.
67. - Improved management of pois.
68. - Change of site penalties icons.
69. - 6 car collections 2D customizable by the user (use GJM collection)
70.- Arrive Settings
รสชาติน้ำแข็งใสที่มีรูปแบบหน้าตาแตกต่างกัน ให้เลือกชิมกันมากมาย
เครื่องเคียง ทำให้รสชาติกลมกล่อมมากขึ้น
ที่สำคัญน้ำแข็งใสถ้วยนี้จัดวาง Junction View ได้ตามใจชอบ กลาง หรือ ข้างก็ได้หมด
เสียงเตือน ในการชิมน้ำแข็งใส
และสามารถเตือนความจำผ่านจานน้ำแข็งใสได้อีกด้วย ถือว่าเป็นความแปลกใหม่
ภาพขนม (รถ) มากมายให้เลือก รวมทั้งภาพของน้ำแข็งใสสำเร็จรูปด้วย
น้ำแข็งใส หลากรส
Thank : KEMAl by Navi-gpsforum
« แก้ไขครั้งสุดท้าย: 27 พฤษภาคม 2012, 19:50:50 โดย ✄PiGGer✄ » บันทึกการเข้า
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #21 เมื่อ: 11 มีนาคม 2012, 09:05:04 »
ผมไม่ต้องการเสียงเตือนจากในระบบ  skin ที่เป็นเสียงต่างชาติ  เตือน speed limit  จำกัดความเร็ว  กับเตือน speedcam   เพราะชอบเสียงเตือนจากนาริสามากกว่า  พอไปปิดไม่ให้เสียงฝรั่งร้องเตือนกลายเป็นปิดเสียงนาริสาไปด้วย  พอลองเปลี่ยนเสียงเตือนฝรั่งเป็นเสียงดนตรีแทน  ก็มักจะดังขัดจังหวะขณะที่นา่ริสากำลังจะพูดพอดี  ทำให้พูดไม่จบประโยค   เคยลองเอาชุดเสียง  audio  ออกจากโปรแกรมไปเลย   ปรากฎว่าค้างขณะนำทาง  เข้าใจว่าระบบจะส่งเสียงเตือนแต่ไม่พบไฟล์เสียง
ไล่ไปไล่มาเลยลองแก้ใน  ไฟล์  igo9.ini   ซึ่งอยู่ใน  branding \ project_config \
พอเปิด  igo9.ini  แล้วลองลบ
[sound.announcer]
overspeedlimit_source=ui
และ
[subscriptions.community_speedcam]
timelimit_warnings=7,1
เพื่อไม่ใช้เสียงเตือนจากชุด skin  ทำงาน   แต่เสียงอย่างอื่นยังมีอยู่ เช่น เสียงแนเะนำเข้า ออก โปรแกรม
คำถาม คือ หากผมลบสองท่อนข้างต้นนั้นออกจะถูกหรือไม่ครับ
ซึ่งได้ลองระยะทางสั้นๆรู้สึกว่าช่วยได้บ้าง   ยังไม่มีเสียงฝรั่งส่งเสียงเตือน  โดยนาริสายังทำงานปกติอยู่
ทดสอบให้แล้วนะครับ คำสั่งดังกล่าวไม่ส่งผลใด ๆ กับเสียงเตือนนะครับ
เพิ่มเติม ภาพเตือนแบบใหม่ เป็นการใช้งานส่วนตัวของผม จึงอาจจะไม่ตรงกับแบบเดิมนะครับ
Awat
ID number: 33936
Send Money to Awat
-ได้ให้: 14
« ตอบ #22 เมื่อ: 09 เมษายน 2012, 15:47:54 »
File ถูกลบหมดแล้วครับ ถ้าจะ Download ที่อื่นมีไม๊ครับ
nirut1975
ID number: 695
กระทู้: 18
Send Money to nirut1975
-ได้ให้: 82
« ตอบ #23 เมื่อ: 09 เมษายน 2012, 23:06:51 »
อยากได้บ้างแต่ไฟล์โดนลบไปแล้ว ขอได้จากที่ไหนบ้างครับ
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #24 เมื่อ: 10 เมษายน 2012, 08:50:27 »
ตอนนี้ไม่มีเนทครับ  ออนผ่านมือถืออีก 3 วันจะ up ให้ใหม่ครับ   ร้อน
pum007
ID number: 2758
กระทู้: 37
Send Money to pum007
-ได้ให้: 32
-ได้รับ: 75
« ตอบ #25 เมื่อ: 11 เมษายน 2012, 11:53:55 »
เพิ่งเข้ามาเห็นอ่ะ รบกวนช่วยอัพให้หน่อยได้มั๊ย ลิ๊งค์เก่าโดนลบไปหมดแล้ว
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #26 เมื่อ: 12 เมษายน 2012, 22:54:26 »
น้ำแข็งใสที่ผมเหลืออยู่ 480x272 สำหรับจานอื่น ไม่ได้เก็บไฟล์ไว้นะครับ ต้องขอโทษด้วยครับ
วันนี้ !!!! สนใจเชิญนำไปชิมที่หัวกระทู้ได้แล้วครับ
« แก้ไขครั้งสุดท้าย: 12 เมษายน 2012, 23:00:16 โดย ✄PiGGer✄ » บันทึกการเข้า
astkul
LT Membersvip
ID number: 4724
กระทู้: 88
Send Money to astkul
-ได้ให้: 63
-ได้รับ: 589
« ตอบ #27 เมื่อ: 26 พฤษภาคม 2012, 09:14:33 »
Link ตายไปแล้วครับรบกวนช่วยทำ Link ใหม่ด้วยครับ  อวกเป็นเลือด
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #28 เมื่อ: 27 พฤษภาคม 2012, 09:37:05 »
รอหน่อยครับ ช่วงนี้อยู่ระหว่างสัญจร ขโมย
surong
ID number: 13265
กระทู้: 158
$109.00 credits
Send Money to surong
-ได้ให้: 192
-ได้รับ: 145
« ตอบ #29 เมื่อ: 27 พฤษภาคม 2012, 10:21:33 »
อยากลองเหมือนกัน แก้ link แล้วจะได้โหลดดู  อาบน้ำอุ่น ๆ อาบน้ำอุ่น ๆ
✄PiGGer✄
s8lt memberDonate
ID number: 3608
กระทู้: 1047
-ได้ให้: 856
-ได้รับ: 3125
« ตอบ #30 เมื่อ: 27 พฤษภาคม 2012, 19:52:12 »
up ให้แล้วครับ อยู่หน้าแรก  ชัยโย
kai1970
ID number: 18415
Send Money to kai1970
-ได้ให้: 26
surasit kongbangkhem
« ตอบ #31 เมื่อ: 09 กันยายน 2012, 09:19:14 »
ขอบคุณมากครับ ผมมือใหม่ขอเอาไปลองครับ แล้วก้อ Link ยังใช้ได้ครับ
Donateผู้สนับสนุน
ID number: 2205
« ตอบ #32 เมื่อ: 09 กันยายน 2012, 09:23:57 »
ความคิดเห็น Global Mod แนะนำว่า ขอบคุณให้กดปุ่ม Thank สีเขียวด้านบนขวามือกระทู้ของคนที่ต้องการดีกว่าครับ และหากทดลองโปรแกรมแล้วได้ผลอย่างไรค่อยมาบอกผลดีกว่าครับ จะเอาไปลอง ก็โหลดไปใชได้เลยจ้า ไม่ต้องบอกว่า ขอเอาไปลองจ้า
GJmpp_v1.12D silver A66 F63 and Gold
^SuRaYoOt^ 2 4939 กระทู้ล่าสุด 27 กรกฎาคม 2010, 10:40:51
โดย Papabear
Skin Mod Silver BRUNODU91
^SuRaYoOt^ 0 3156 กระทู้ล่าสุด 30 กันยายน 2010, 01:54:16
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.068 วินาที กับ 64 คำสั่ง
