V 5.0 ONLY FOR PRIMO 1.2
Compatible with primary and 9.2.1.X 9.2.0.X
800x480 480x272 320x240
- New presentation of the menu buttons day mode (taken from Dimka)
- New presentation of the menu buttons night mode (taken from Dimka)
- Compatible with the "LoadingChanger of PicPic45"
- Return of the bottom button "More" menu "search on the map"
- Fixed bug of "Autochanger-night"
- Various fixes
Ability to customize the messages of welcome and TTS output by adding the sys.txt
[Tts]
start_annonce = "Write the sentence personalized welcome"
exit_annonce = "Write the sentence custom output"
- Added dynamic volume of Dimka skin
- Added sound alert 'power' if non TTS voice
- The start-up and non-TTS voice output if
- Moving the Settings button speeding and DA in the system settings of the skin
- Added display in the Navigation of the name of the town or village through => Simple mode, or off mode actually
- Change the color brown in the cockpit information
- Ability to set the relief information displayed in the cockpit navigation
- Click on a time in the navigation screen directly change the color information
- Possibility to change the display format of the time in settings
- Added display in the navigation screen of what the real-time TMC, TMC received signal, frequency, station (to adjust) click above refers to the frequency list TMC
- Add button icons TMC TMC number info, it can be disabled in the settings
- Choosing the color settings of the current speed in the cockpit without speeding, with the possibility of a change in long-click speed if the option is enabled in the system settings
- Fix the PDA is adjustable in the system settings
- Ability to change the preset speed to 15 km / h for triggering the Autorad, 10 to 25 km / h, any value above or below will be given to maximum and minimum possible to put it in the sys.txt
[Autorad]
detect = (your value)
- Ability to change the edition of a POI (Thanks to Jeanm1242) => The icon and phone number / spoiler]
[Spoiler = History] Version 5.0
- Fixed bug Panic function
- Added the function "Autorad" Team of the Sbertaud, you can disable the "Autorad" by a long click on the top right
info button "I" in the screen "DragMode" (where it activates the mapchanger) with possibility to cancel the fontion completely by adding the sys.txt
[Warning]
autorad = "0"
- Added 'patch to fix PDA ", you can disable it by adding in the sys.txt
[Utility]
calibratefix = "0"
